well for the 1st time installing injectors in my life i think i did pretty well. only four problems
1. the directions disappeared for about 20min. finally i found them they where lodged in my bumper and took 5min. to retrieve them.
2. the injectors did not want to seat properly i guess the injector chambers was too dirty.
3. wasnt sure which washer to install. the directions said install the . 020 washers well there where 3 d/f sizes that came in the install kit. but remembered someone posting that it was the smallest in the set so i went with my memory and i was correct.
4. it was getting late and i drop my 7/16 socket down the inter cooler boot. dont ask how well that ment crawling under the truck and using a open end wrench to back of hose clamp took forever.
now for impressions
1. a really nice power add very little smoke.
2. well worth $300
questions
1. when i pulled the #1 injector it was covered in a milky brown goo. the rest of the injectors where covered in a black goo. whats up with that. it look like oil that was saturated in water.
2. idle is lower. when i put it in gear with the a/c on my rpms go to 400 and the truck is on the verge of dying and will die if you goose it a little and then let off what can i do? when in park it idles at the right rpms maybe 50 lower but put it in gear and it will stumble. the truck once off idle runs better than it did with the 180 injectors. help me on this one.
comment :for those who are scared of doing the injector install yourself do it b/c its simple. MAKE SURE YOU HAVE A GOOD PULLER. I USED A LUG NUT OFF MY DUALLY WITH A PIECE IF 1"X1 1/4" PVC THEN PUT THE LUG NUT OVER THE PVC AND SCREWED IT ON THE INJECTOR POPPED RIGHT OFF.
now for impressions
2. well worth $300
questions
