I'm going to try this one more time. Get a few M14x1. 5 MM nuts and you can use screw them onto the injectors and wiggle them out with a pair of vise grips after you take the lines off as a set... hint, hint! When you install the lines leave the retainers loose till after you have bleed the lines, then tighten them last so everything will line up nice. Use some carb cleaner around the base of the injector before you pull them to loosen things up! The retainer nut is 15/16th's deep socket
Jim
