I've been thinking about stepping up to 37s. I've done a little looking and measuring and I think I might be able to make it work if I grind down the pinch weld seam at the back of the front fender and cut a little of the plastic at the front. The rear tires don't look like they'll be a problem at all.
I know grinding down the pinch weld may not be a great idea but I'd only have to grind down a few inches of it and also I was thinking I could brace that back up with a piece of sheet metal welded over it flat.
Anybody who has tried fitting 37s, I'd appreciate any advice you can give. Thanks.
