There are several different type s of Roloc discs the multiple finger style, buffer pads,grinding pads The finger and grinder type will remove metal, the buffer pads are much safer I have used them with care and have had no problems. All the heads gaskets I have done I run a very thick wide ******* file across the head and block to see if there is some "low" spots, going one way and the other will show the low spots.
I have seen a chronic oil leak do to the use of grinder pads on an aluminum housing, couldn't see it with the eye but put a straight edge on it and it was very apparent, had to replace the acc drive housing to fix it, very expensive for a simple mistake.
Craig
