3rd gen cold idle problems
any way to keep pressure in check with pressure box
Intercoolers
I have owned an '05 since May of this year. Prior to this I had an '03 S. O. A comparison between the 2 is what sparks my concern. First, I noticed my '05 smokes quite a bit (black) more than the '03 under patial or full throttle. Even after a full throttle blast ( to clean it out) it still smokes just as much. Mileage around town is 16-17 & 20-21 on the freeway. Performance is excellent. Now that winter has arrived, this thing starts & idles poorly compared to the '03. Once the engine has a little temp in it, its OK. At first I attributed this to fuel, but have now ruled that out. Has anyone had similar experience with their truck? In advance, sorry for being a little long winded.
P. S. The '03 was stock at first & then added an Edge box with Banks exhaust.
The '05 is stock with 8,000 miles on it.
Tim
Mine does pretty much the same thing. I think the black smoke you are seeing is just the CAT cleaning the soot out of itself. Mine will always do it worse after a long run at steady speeds but will do it on hard acceleration also.
White smoke and a rough idle on cold start uo is normal. If you have an auto turn on the high idle and it should smooth right out. If you have a manual you can do a little work to enable the high idle. Works greta for cold weather warm ups. ;)
go to the dealer and have the fast idle software installed their was a tsb about being able to have it done it will idle up to 1500 rpm works gerat on those cold mornings
scottmcd said:
Is the fast idle TSB good for Manual Trans? TIA, Scott
Nope. The manual fast idle (using the cruise control buttons) only works for automatics.
Some 6-shooter guys are using a stick between the acellerator pedal and the driver's seat. Use the electric seat controls to adust the idle speed.
Bob
HTML:
Not quite true. The fast idle parameters are in the PCM and can be activated on the manuals. DC has a kit for the 06's that should work on the older trucks that includes a clutch swith to disable the fast idle. The other option is to ground pin 21 on the b connector, PTO I believe, and be careful. With a little engineering it is possible. :)
