3rd gen wheel weight?
installed a dss
Water-n-Fuel sensor after FASS??
anyone happen to know off hand the weight of a 3rd gen polished or non polished wheel?
just trying to compare to the 2nd gen weights
thanks
Carl
According to http://www.dodge.com/bodybuilder, the 2004 cast aluminum wheels are 24. 5 lbs. Chrome clad steel wheel is 42 lbs.
From after selecting the year and model, select Technical Info from the main menu. You need to look at the model code chart first (RAM 2500/3500's are DR2, DR3, DR7, and DR8). Then select Truck Wheels ...
klenger posted numbers are accurate, I weighed both with and without BFG 315s. BFG 315s on stock Chrome Clad steel wheel weighed about 107. 5lbs. I have 5 with matching spare, almost 540lbs of tires and wheels.
It's hard to believe with the tire on the rim that it gains that the combination gets up to 107 lbs. But when I rotate them I don't have a problem believing.
