Well... I put it all together yesterday. I turned it into an all-day job but I think it could be easily done in a few hours if you have everything you need at arms length. The instructions that came with the BD kit were slightly different than the ones I downloaded. They call for a 1/2" bit for the cross member holes in one and a 9/16" in the other. 9/16" was correct. Getting the new track bar on was no picnic. It didn't seem to want to line up right. I re-centered the axle after it was done and it moved the steering wheel from the 10 o'clock to the two o'clock position. After I redid the steering components last month the two end links on the drag link were touching so the wheel was stuck at ten. It was driving me nuts. I re-centered the wheel after the test drive. The new setup made a huge difference. The steering rock solid. No wander, no wobble, no hammering over bumps. The new bar makes contact with the bracket when the suspension is compressed. I'm going to call BD about that this week. It's slight but for $428, I want to know if I can correct it.
