3rd generations...Newbe..Code questions.
Powertrain Control Module Location
Not sure if what I am seeing are codes or not. If I hold my odometer button down and turn on the key every thing on the dash lights up, tach and speedo jump up and down in steps and then it will spit out ## ## codes. What is that I am seeing? If they are codes where can I look them up?
Thanks,
Those are the instument cluster codes.
To get the P-codes, you need to cycle the ignition from "off" to "run" three times in rapid succession, leaving it in "run" the last time. Don't bump the starter or you'll have to start over.
Bob
Bob
Wow codes for the guages even. Anywhere to look those up?
I will check the P-codes if there are any...
Thank you.
