Has anyone upgraded the stock battery cables to 4/0 size?
Did it help much with starter improvement?
I've never seen it posted. It may be that most of us consider the 1/0 & 2/0 cables used in the diesel starting system as more than adequate. The problems with the starting system that I recall involve batteries, starter contacts, corrosion, and ill-fitting soft lead die cast clamps at the battery terminals. The die cast clamps only get worse with each "disconnect the batteries" warning.Silver_Ram said:Has anyone upgraded the stock battery cables to 4/0 size? Did it help much with starter improvement?
Your 450 amps is on the low side for current draw of an engine at operating temperature - the FSM suggests it can be more than 700 amps for a cold, tight engine. The fact that the cables are out in the air and are used for such a short time has to be considered. I think the Nippon Denso starter motor would experience meltdown long before larger cables were needed.I am going to make my own cables and go with the mitiltary posts. I am tired of the vehicle manufacturers building the cables you can only get at the dealer. I was thinking that since the 4/0 cable is closer rated to the 450 amps the starter uses to start the truck, I would upgrade...
I don't know how it is model year 1997 but all Factory Service Manuals 2000-2006 state large eyelet type terminals are crimped onto the ... battery cable wire and then solder-dipped.gathomas said:... The 2/0 factory cable that goes to the starter is a compression (crimped) lug. Not the best in terms of resistance...
Silver_Ram said:I started the post to see if anyone had 4/0 battery cables already.
The cable I'm going to get from Quick Cable is tinned & temperature rated for 257 degrees F. The insulation is also abrasion, salt & chemical resistant. It's UL listed as well.
I bought some putty & gonna check the clearances between the hood & the radiator. The price difference between 2/0 & 4/0 is very little. This cable is expensive & I have to buy a minimum of 25 feet.
I already bought a set of Hexcrimps & the cable cutter, so a little more overtime & I can get the cable.
OEM cables in good shape can be altered to use the military battery clamps: https://www.turbodieselregister.com/user_gallery/sizeimage.php?&photoid=23125
Link no work? what kind of clamp is this and where do you find therm?
