To help better you might want to complete the ?
What are you wanting to do with the batteries ? I'm guessing run something off them being that this is the tow/RV .
But like others have said all batt. need to be the same , make , model , age - a battery is a bank of cells , one 12v batt. is realy 6, 2 1/5 volt cells [ if they are lead acid ]
When building a bank if you connect + to - you build volts , if you connect +to + you build amps.
If you want to run devices off of this bank , start with deep cycles , and not the marine rv batteries they are a compromise and do a bad job of both -starting & deep cycle.
