Engine/Transmission (1998.5 - 2002) 4+4 question
Engine/Transmission (1994 - 1998) Transfer Case Oil
Engine/Transmission (1998.5 - 2002) Turbo Modifications
Junk 4+4 question
on my 99 dodge the dang thing keeps poping out of 4 wheel the light stays lit and i have adjusted the linkige but it still dos it. also just rebuilt the front end new bushings bearings seals still dont work . also changed the actuator. is it possibly the vacume pump i dont think it is . i wouldnt have any breaks if it wasnt working what do you guys think -thanks josh
Don't know on your 99, but my 01 the brake booster is hydraulic, "Hydro-boost", works off of the P/S pump, so the vacuum pump wouldn't matter. Is the transfer case popping out or the front hubs not locking?? if it's the transfer case, there is a detent that locks in when you shift it to 4WD. So you might be looking at getting that fixed, sometimes they do that when they are worn.
Tom
2001. 5 2500 4X4 5-Spd LB QC Black. Catcher ECM, DD Stage-1's, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, Silencer Ring MIA, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
My dad has bent the fork that engages the collar in the front diff a couple of times. That makes it pop out under a load.
My brother had his t case apart and mistakenly put the collar that locks the gears together in backwards. 4wd wouldn't work either. If you haven't had the tcase apart then that is probably not the problem.
Michael
Mine has pop out of 4L a couple of times. It was pretty violent the last time it did it. I had a massive load of wood 4 wheeling up a steep grade. It did not sound the greatest. I think something is not right with my t-case. I am not going to worry about it cause I do not use 4L often.
Brian
