4 bolts on top of valve cover????
Question about dual CP3s
Stacking MP/8 with TST!!!!!
I was checking my oil today and noticed that the two front BOlts on the valve over, up on top, just behind the Oil fill hole were seeping a little bit. One of them I could screw downa bit tighter the other seemed tight. . Looks like there is a rubber washer for each??? I degreased and wiped them down to monitor. If I had too, could I just unscrew them and replace the washer??? Wouldn't hurt anything would it? Thanks!! :p
O-rings... ... ... no problem pulling the bolts out to change them out. You will want to put a light film of oil on the o-rings to prevent the new ones from tearing.
Bob
Thanks Bob!! Would I just pick them up from the dealer???? Truck goes in tomorrow for them to listen to the A/C noise coming from the condensor. . I will ask about the O-rings. .
