I've been working on a 4BTA conversion for some time now and need a question answered about the routing path for a 4" exhaust in an '85 Dodge Ram Prospector 4x4. This should be the same as a 1st generation Cummins equipped Ram. My NP208's front driveshaft output comes up the driver's side of the main driveline. I see a some space between the transfer case and the driver's side frame rail and above the transmission support cross-member. Is this where the 1st gen. 4x4's exhaust runs? If I try and pass the 4" exhaust through going above the cross member I'll be only 2" away from the transfer case.
