I dont sell exhaust systems nor am I affiliated with anyone that does.
IMO exhaust is a waist of your money IF: you are looking for a performance enhancement. there are other things that cost as much and less then some, that will get you a bigger performance gain.
IF... . you are looking for sound changes, then have at it.
I dont know if you have heard of Joseph Donnelly or not. if not, he has done extensive Dynomometer testing and can back up what he says with PROOF. attached is a quote from Joe that he left in another exhausting discussion earlier this week.
"At your power level, no difference between 3" and whatever bigger size you choose. At 380 rear wheel hp, you gain 7 hp with 4" and no muffler over 3" with a Walker 21468 muffler. Above 350 hp, the HX40 is valuable to lower egt, and it is designed for 4". Sickly has run 613 hp through 4" on #2 only. If you want bigger for appearance or sound, that is another thing" -JOE D. auth. -
the above would apply to your situation also. exhaust is worth about 25F off a stock trucks EGT's. a Psychotty air system or others alike (the one I am developing) can take off as much as 200F.
the first thing you should do is get some guages. next if you want more power (50-100HP over stock) but not alot more power (100+) then get a "box" EZ, VA, TST or ??, and be done with it.
again. if you want to change the sound of your truck then go for it.
if you want/need more power do other things FIRST.
as stated before, explore ALL avenues before loping down your hard earned money, anywhere.
