I am straight Piped, no muffs
I'll give you a bit of history behind my exhaust, and my so called reasoning.
I have a friend who has a '79 3/4 ton Chevy 4-speed with a 350 motor, he has true dual 2" or 2. 5" pipes with 7" glasspacks (length)
His truck when at WOT can easily be heard from 1/4 mile away, and is actually quiet in the cab, the most prominant noise is the drivetrain.
I wanted his type of setup,, Loud outside, quiet inside.
Well, I didn't get it. The resonance at 70MPH gets bad if you do anymore than about 15-30 minutes of steady 70MPH.
If I travel at 1,500RPMs the exhaust is a ALOT quieter, and above 2K the resonance is not any worse, but is still bad.
The driver side, and Back pass. side are the worst resonating spots, the Passenger side has the least resonance,, it's nearly non-exsistant, the only noise is the actual exhaust while accelerating, and the turbo whistle while decelerating.
*I* LOVE the sound, INSANE Turbo Noise. The Turbo isn't louder than the actual exhaust at WOT, but while slowing down any, the trubo can be heard whistlin' in the wind. .
If I could compare the interior noise to anything, it would be to a vehicle with open headers dumping right behind the cab.
Maybe you could put some mufflers on it, and it would get rid of the resonance.
You can look up TDR member "Brian Hopper" and he has the same exhaust setup, but exits farther back.
Anymore questions? feel free to ask.
MerrickNJr
P. S. I have 600watts of bass underneath the rear-seat, and the resonance is nowhere to be found, if you listen to the radio the resonance will be ALOT less, but for me, the radio is ON (loud) or OFF.
