Has anyone out there tried replacing the one piston caliper/rear drum braking system with the 2 piston caliper, four wheel disc brakes from the 2001. 5 RAM? Mechanically, the parts should fit as a Dana 80 is still a Dana 80, but would the old master cylinder be able to supply an adequate volume/pressure of brake fluid for all those extra pistons? Parking brake actuation might also be interesting, but installing a new pedal wouldn't exactly be rocket science.
Why, you ask? I dunno; it would seem to the mechanically unsophisticated (myself) that greater braking performance through improved cooling and the greater clamping force of dual pistons may relieve some of the excitement of downhill trailering. Similarly, the self adjusting nature of disc brakes may end the directional instability during braking that has been such a problem in the past or has that one been solved already?
2001. 5 drivers; have any of you noticed any great improvement over previous RAM brakes? Would a conversion be worth it?
'97 2500 SLT, 5 sp, 4X4, 3. 54 LSD, Camper and Trailer Packages; awaiting first BOMBing
