Ok people I'm having a major problem here. It seems my 4 wheel drive is trying to engage while driving down the road.
This started happening about a 2 or 3 weeks now I guess? You would hit a bump in the road and either one side or the other would start whining really loudly like a hub was going out. Well I took it to my local shop that I have my work done at. They looked it over and replaced the pass. side hub under warrenty(I had both done last year). Well after that hub replacement the problem was still evident, and got worse as time went by. Finally I arranged to leave my truck with the shop for a few days to let them look it over.
What they discovered was the 4wd trying to engage when hitting a good size bump in the road, and that if you pull back slightly('bout 2" or so) on the 4wd lever it will quit. So they said they bench tested my actuator on the front axle and it seemed ok. They told me that it needed a new vaccume switch, but by this time I had to have my truck back so I replaced the vaccume switch on the transfer case myself and the problem is still there.
After talking with the shop they seemed to think its a loss of vaccume somewhere causing the actuator to try and engage? Does that make sense?
I was getting my truck ready to sell because I want a club cab, and now this kink has been thrown my way. Does anybody have any idea what could be wrong with my 4wd system
