Engine/Transmission (1998.5 - 2002) 40 HP 50 ftlbs from turbo
Just thought I would let everyone know that I had a great experience, at Dyno-Mite Diesel in Monroe today. I called a couple of days ago to ask them about drive pressure, since I was getting almost 42 lbs of boost out of my hy35. They informed me that I was risking head gasket failure, if I continued to use the hy35. Matt and Lenny recommended that I buy a larger turbo, to keep the drive pressure low, and to provide more air for when I am ready for injectors. I had the turbo installed today, and to my surprise they dyno'd the truck. Matt let me know that I had gained 40 HP and 50 ft LBS. I had no idea that without adding some more fuel that I would gain that much HP. These guys really know how to make real horsepower. Thanks Dyno-Mite!
I am not sure exactly. I would look at the reciept, but I had to leave quick, and forgot it. You can give them a call @ 360-794-7974, and I will try and call them tomorrow so I can let you know what it is exactly.
Ross, how could you let some one work on your Dodge and not know what they are putting on it? You always have to know! You could end up with a chev or ford. All kidding aside, could you let us know what model it is when you find out , as others are interested. Thanks Ross
jack
Well, I called Dyno-Mite today to figure out what they put in my truck. They let me know that what I got is a High Tech brand turbo. It is apparently suited to the 500 horse range, which is my goal. I hope this info helps.
