Get some big injectors, big delivery valves (191's or laser cut), #4 plate or custom grind, do the usual exhaust BOMBs (get rid of it all... ), set the timing to a healthy number... watch the gauges peg and hold on tight... . you'll be pretty close to 400rwhp, if not more.
All the little 'tune-up' stuff must be done too. Make sure you have clean filters, valves adjusted, proper fuel pressure, etc.
I've seen stock turbos make 400rwhp, is it good for them?... No. Does it work?... Oh yeah!
If you want to do all this without soot, forget about it... . you'd be dreaming in 3-D color with DTS 5. 1 Surround Sound.
Matt
