405RWHP Duramax
Newbie Swears Chevy has the Cummins
Why no 4X4 Medium Duties?
I just got this off TDP. Someone wanted to know if you could stack boxes for more power.
You can stack the boxes just fine without too much of a problem; if you take the timing out of one of the boxes. Our Duramax dyno'd at 405HP with just over 900ftlbs once the AMP and the Dynomite were configured correctly. The dynomite should be good for an additional 30-50 HP over the present Juice/AMP box. Althought the Duramax will run with a ridicalous amount of timing advance, it is obvisouly not the best thing for the engine, especially when you run propane. We have the ability to remove the timing from the Dynomite as so should some other shops around the country.
Christian Roth
-- email address removed --
www.bd-power.com
1. 800. 887. 5030
Originally posted by nickleinonen
you trying to light a fire under these cummins boys here?:eek: ?:eek: ?
lol :) :) ;)
I dont think a fire needs to be lite under us Cummins owners. I thnk the fire is still under the ferd and cheby guys. They STILL cant keep up. :D
It's alot of power for just plug in mods. I know there are tons of plug in mods for the Cummins, which ones will give 400rwhp or more?
