I need tech help on my '75(see signature). Its got a fresh 440 that hasn't any miles on it yet because I can't keep coolant in it. For the 440 people out there the exhaust manifold bolt holes in the head, at the front and rear of the head are drilled into coolant passages. I can't get the rearmost hole in both sides to seal up. I tried the header bolts that came with the headers, then longer 3/8" bolts thinking the header bolts were not long enough for a good seal. I have now also tried long studs from a 3406 cat that completely bottom out in the threaded holes with no avail. I have used silicon, gasket maker from CAT, Pipe sealant, and then some really good sealant from CAT too, to no avail. I don't think the heads are cracked, I have had other 440's and haven't had this problem.
Can any one help? Please? Memorial day weekend in dresser wis. is comming very rapidly and the truck still hasn't gone around the block yet!!!
