i have tried two aftermarket valve bodies no change
Replaced the primary gov valve in the back of the trans, the brass weights apparently are not available anywhere new.
Line pressure is 100 psi
Replaced gov support in case of cross leak in the OD unit from possible wear. No change.
I have increased tv cable pressure at the stop bolt on the valve body. .750
I am out of ideas lol!!
Trans works ok and drops into first for a while when cool then as soon as it has any temp at all it stops going into first gear unless I go to neutral the back to drive
tV cable is adjusted correctly
Gov pressure when I come to a stop is absolute zero on a 100psi auto meter pro Comp gauge. I know there is someone out there that has solved this problem! Any new ideas ??
