Not trying to beat a dead horse here but i have a problem with a new truck i just picked up. Its a 95 Dodge 2500 with an auto and 4:10 gears, 218,000 miles. The problem is i have no OD or lockup when driving normally. Its does not even try to go in, so I hit 61 mph at red line. But here is the kicker, when i go down a long grade with no throttle or very light throttle it kicked into OD but then quickly left. I swapped a known good TPS and no change, i tried the resistor trick in the temp sensor, no change, I tried to clean grounds and cleaned up the terminals on the ECM, no change. I also swapped a OD button, no change. What else am I missing? The guy I bought this truck from said it was rebuilt not too long ago but is out of warrenty on the rebuild.
Ive read about every forum i could find and tried most all of the solutions to see if i could fix this issue. I'm not an automatic guy so I thought i'd give it one last try before taking it to a shop. ANY INPUT PLEASE
