Engine/Transmission (1998.5 - 2002) 47re 2 to 3rd gear shift problem
Engine/Transmission (1994 - 1998) help need a mechanic
Ok guys first off I want to say I"m not bashing anybody I just need sum help. I just had my 2nd suncoast transmission put in. After install I noticed it had 2nd gear take off. I called them and they told me I needed a resistor in the 31 pin contector,I did that today and fixed it. But the problem is now under normal driving all shifts are firm and hard hitting. When you rage on it from a start, 1 to 2nd is great but 2 to 3rd has a flash. I was told to adjust the tv cable,I did that but no change.
I"m just confused first I had to install a resistor in it ,which I didnt need before ,now the 2nd to 3rd gear shift flash which I had in the last transmission. but is a little better now but still a problem,has anybody else had the same problem if so what fixed the problem any help will be nice. I"m calling Joe in the morning but other help is nice to have too. Thanks
