fluid change
To use the cooler line method, you first service the pan, then hook up a hose to the return cooler line(the one that connects to the rear of case) secure to the pan or container (will have pressure in hose) put 5 or 6 qts of ATF+3 in trans, have helper(makes this a bit easier) start truck in neutral with park brake applied, add fluid while truck is running(4 or 5 qts) this will allow fluid to be pumped into converter forcing old fluid out. Shut off truck, reconnect cooler line, start truck and bring fluid level to full mark. This is the short version, I hope you get the idea. Dropping the pan and loosening the valvebody will at best only allow 1/2 the fluid to drain out of the converter. The DTT converter comes with a drain plug which makes this a much easier process. Hope this helps.
James Northum
DTT installer/dealer/Bill K. approved trans builder
