I've spent 45 years as a shadetree mechanic in the U. K, but solely on manual gearbox vehicles. I've rebuilt engines and gearboxes, but the auto transmission is a new box of tricks, and, even having studied the schematics of the 47RE auto,and having driven and maintained it for ten years, I still have a great amount of ignorance of the simplest issues. Here are a few of my queries, which mainly relate to keeping the transmission operating for as many miles as possible, with the highest reliability:
1. Waiting at stop lights, my inclination is to shift to P. If I leave it in D, will this shorten the life of the transmisssion, or will it just generate heat, which might be a good or a bad thing? ( I have a trans temperature guage on the output line, and I keep below 200 degrees. )
2. I have altered the overdrive switching so that default is "no O. D", and I have to select O. D manually. I prefer this, particularly when towing, to avoid lugging. I tend to accelerate in 3rd up to perhaps 50 mph, and only then drop into O. D. Is this reasonable?
3. When towing, the '98 Dodge Owner's manual at Page 123 says not to use O. D. (I may be misinterpreting the manual) Also, the engine defuels at about 2600 rpm. In theory, then, the truck should not pull a trailer over about 65 mph. If I'm towing my 6500 pound Airstream travel trailer on a level highway, with no strong headwind, am I truly risking my clutches by going into O. D, and back to top on the slightest grade? I have a BD torque-lock, which increases the line pressure at low rpms. I get 13 mph towing in 3rd, and 15 mph in OD, with far less noise to disturb the passengers. Speed is about 63 mph.
4. Although I change the transmission fluid and filter regularly, I have avoided adjusting the bands. I feel that, even with the information from my full Chrysler workshop manual, this is a risky procedure when the transmission is always shifting correctly. I have read contrary views. One is that the band adjustments can be ignored on a 47RE, and the other is that regular band adjustment is important. What do the TDR gurus recommend?
5. I'd rather replace a unit before it leaves me stranded at the roadside. Am I likely to get warning of a failing transmission? Mine has 160. 000 miles and it operates perfectly. I aim to keep this truck for the rest of my driving days. The torque converter seems loose, but I understand this is to protect the transmission from the Cummins torque. What would be the warning signs? More TC slippage?
6. The '98 shop manual at pages 21-99 and 21-100 describes a stall test for the TC. This seems a brutal procedure, and hence I have avoided it as a means of assessing the slippage of the TC. Should I be wary of this procedure?
7. I am accustomed to hauling heavy loads, and we all know that at the beginning of a down grade when hauling heavy, one should shift to a low gear to use engine braking. Hence I was stunned to discover that the 47RE unlocks the TC under these circumstances, and the truck can freewheel to its doom down the grade. I immediately had a BD exhaust brake and Auto-lock fitted to the truck. Why would anyone think that forcing a TC unlock in these circumstances in a heavy duty truck was a good idea? Was this to meet a fuel consumption government target? By making the truck less safe? Really?
8. Fitting an exhaust brake to these trannies is a contentious issue. I like to use mine all the time, even when running empty. This suits my driving style, as I try to avoid using the foot brake unless coming to a stop. This gives the passengers a smooth ride, helps fuel economy, and prolongs brake life. However, am I risking wearing out the auto transmission clutches by always using the exhaust brake?
9. Does one get faster acceleration with or without TC lockup in a stock 98 12 valve in everyday driving? Intuitively I would have thought that a locked TC would avoid slippage, and thus be better for acceleration. However, there is the torque multiplication effect of the slipping TC. Also, there is the issue of fluid temperature with the unlocked TC. I have fitted a red LED in the dash to indicate TC lockup, and a transmission temperature gauge.
I'd be very interested to know the answers to these questions.
Nick.
Nick.
