I have a '97 with a 47re that will start in 1st gear and shift into 3rd gear within 100 feet of movement with normal throttle %. The TC will still lock up on it's own at 30-35 mph. The TPS has 1 volt at idle and the TV cable is adjusted properly. The truck had this problem before the transmission was just rebuilt, so I am assuming the problem is in the truck somewhere. .
It has a new trans speed sensor, but makes no difference if it is hooked up or not. .
It has a Delphi (GM) governor Solenoid.
New valve body.
I'm ridiculously baffled by this, so if someone could help me out, I'd greatly appreciate it... Thanks in advance... .
New valve body.
