47RE in a 1st Gen?
HELP turbine making contact with housing...
Thermostat for 1st Gen
Yes it is possible. Bill K and I talked about it and I decided fluid coupling is the way to go for me. Lock up has its goods and bads like everything else.
You would have to change alot of things. Why bother.
I saw this offered as an option by a vendor and I was suprised.
I have no experience with lockup TCs and probably won't for a long time but it is interesting to discuss.
Side by side what are the pros and cons of each system?
46rh
Pro's / Con's
less electronics, / casing is weaker
less weight / less top end
solid shafts / lower mpg at crusing
better bottom end / exhaust brake is useless
less cost/
You can upgrade casing to better designed later 2nd gen like I had done.
46re
Pro's / Con's
better top end / more electronics
exhaust brake will work some / more weight
casing is stronger / hollow shafts
more mpg / cost more to modify
These are my take on it.
mark
PDR - Black Sheep Racing
As far as the stock input shafts are concerned... . How does the strength of the solid shaft on the 46rh compare to that of the hollow shaft on the 46re?
Sean
46re or 47re?
What year did these come out?
Mark- What year casing do you have. This is getting very confusing now. I'm having my transmission done at the end of the month. DTT TC, VB & updated planetary. My installer says he has a lot of parts so it might be worthwhile to ask. I had not heard of this as an option.
