In another thread I posted about upgrading from the OEM tc to a SunCoast 3 disc w/487 valve body.
All went well except that the transmission was full of dust when the change out was done. We washed everything, flushed the oil cooler and new filter of course.
After about 700 miles, the shift solenoid stopped up and had to be replaced. More fine particles of metal dust in it and the pan. The transmission has now been serviced 4 times at about 800 mile intervals and there is still metal dust, plus the transmission fluid drained out each time is black, not red.
The SunCoast tc has a drain plug, so we are able to do what amounts to a complete flush excluding what is in the transmission itself and the valve body which we aren't taking off each time.
Anyone have a similar experience? And if so, do you think this is just a case of the oil cooler did not clean out as much as I had hoped it would?
The transmission is shifting good and feels good. The check engine light comes on from time to time, but SunCoast says I need to insert a series resistor in the line to the line pressure sensor because their DC487 vavle body increases the line pressures.
Thoughts on this please. I'm of course hoping it will stop making metal and last me for a long time. Replacing the transmission is not in my budget right now. For that matter, the tc and vb went on a credit card. transmission has 116,000 miles on it right now.
Also, I wondering what effect this fine metal dust will have on the new TC ??
