This is my first post on this sight, so here it goes....
yesterday driving on my way to town, my truck was driving and shifting fine. I Shut the truck down and went about my way. When I got back in a few hours later pulling out of the parking lot I noticed that my truck didn't want to shift out of 1st. No mater how high the rpms went it wouldn't shift. Letting off on the throttle I could get it to shift but after shifting, it went through every other gear just fine and the tc locked up just fine. After passing the normal shifting rpm the truck seems to louse power and feels like it's slipping. I took the truck to my mechanic and he hooked his obd2 scanner up and was able to watch my peramaters. I didn't have any crazy codes, but my throttle position sensor was bouncing around between 37 and 48 at IDLE. the scanner was saying my truck was telling it that it was in second gear before it actually shifted when I was moving. I was told that there was static and I needed to re rout the ground wire running on my altanator, and that it could be causing the problem, I know this can cause some problems by causing interference but I had no luck. Fluid level is good and not burnt at all. I am at a loss, any help would be very appreciated! Thanks in advance
