Hey all ,new to TDR ,been reading up on truck problems for awhile. Was reading post on 47rh problem and saw my exact same problem that my truck has! I have a 99, 2500 ,automatic 47RE with only 49,000 miles on it and never had any trans problems at all. Truck sat all night then in morn went and moved it maybe 50 ft to next door neighbors driveway backed it up driveway and put in park and let it sit till around noon then went to leave and truck won't shift!! Takes off like normal but no upshift from 1st or 2nd not sure which one it is in. when I put the gearshift into manual (1,2), and I drop it from 2nd to 1st it acts like it downshifts (A bump), but when I upshift from 1st to 2nd manually it doesnt seem to change. Can only get about 25mph out of it at around 2300rpm. Will speed up with more rpm but didn't want to push it. Ran it up only once to 2800 or so to see if it would shift but no such luck. So far I have tried scanning for codes(at Autozone) but no light is on in dash. Took it in to dealer and hoped they could find problem with there fancy scanner but no such luck, they said it was internal and I need a new transmission, they didn't even drop the pan on it? I decided to hold on to my $3750. 00 for now and see if i could fix it. So far I have changed the fluid and filter and at same time replaced transducer and solenoid in transmission. Cleaned all battery post as they were kinda corroded. Checked the fuses and rely under the hood. Checked all the linkage and the kickdown cable at transmission and throttle linkup. all looks good and tight with no slack or play. All This didn't help! Pulled pan again and checked adjustment on rear band and it seems fine. This is the third time for the pan off and no metal particles found at all! Have to get a new gasket and filter before I put it back together again. Checked all the valves in the valvebody with small rod to make sure they move somewhat and not stuck. The only other thing i am going to try is to replace the drive output/speed sensor, figure it must be something in the electronic side since it happened so suddenly!
Any other suggestions would be appreciated! Truck has been like this for a week, really need to get it back rollin!
