I have had this issue for around 6 months or so.
I will start from the beginning...
Rebuilt transmission 1 year ago.
5-6 months later no lock up.
Tested alternator
Cleaned grounds
Monitored transmission via snap on scanner
Wired in lock up switch
Added noise isolator
Tested continuity on lock up cable to PCM.
Tested apps
Changed VB
Changed solenoids
Changed OSS
Tested brake light switch
All came back good
Trans doesn't slip
TC when it was locking didnt slip at all
TC would lock up only if coasting whilst feathering throttle around 5% tps input. it would lock flick the lock up switch and it would stay locked
Flick the switch and coast it would eventually lock up and stay locked
We had a our first frost friday night saturday TC wont lock at all no matter what..
Done the ATS apps re wire today made no difference other than throwing p0121 code tonight. I'm at a complete loss the only issue I can find is the 8 pin connector on the trans doesn't seat all the way down but this has been like this for the last 2 years no issue.. I have now ordered a connector to replace that.
Does anyone have any further suggestions?
Anyone give me a list of problems that will cause a no lock up situation.
Does this sound like the TC may be toast even though when it did lock it wouldn't slip at all?
Do I buy a standalone controller if so what one is recommended.
Thank you
Tested alternator
Cleaned grounds
Tested apps
Changed VB
Changed solenoids
Changed OSS
All came back good
Trans doesn't slip
Thank you
