I am trying to find out how the 47RH picks its shift points. I understand that it is done by Hydraulic Modulation in the first 3 gears and by PCM for OD and Lock up. How can these be tweaked? Can it be made to shift with out TPS or other computers? I'd be willing to rig some switches up to run a few things it I have too. Just finding out how it functions is a pain, I can find all sorts of GM/Ford BS to read but not much Mopar. I tried a slightly different post in Conversions, without much luck. If I can find out how the darned thing works, or if a cheaper factory transmission manual is available, I can igure out how to put it behind a bomber 4BT est 145HP/450lbs ft lbs.
