Engine/Transmission (1994 - 1998) 47RH rebuild.
Well, my trans. needs a rebuild and I was thinking on trying to do it myself. I think if I take my time, take lots of pics and ask for help every now and then it should all come together. First thing I would like to ask is if there is any specialty tools that one may need to do this sort of thing at home. Also is there anything at first I need to take note of before I start tearing it apart? I checked the in-out movement of the input shaft, what are acceptable tolerances here? I can't remember now for 100% but I think there was 2-3mm in movement front to back. Anyway, any info/help is greatly appreciated. Thanks.
Get a Dodge service manual for your truck. The real thing, not an aftermarket cheapo. It has all you need to know to do the overhaul. You can do it all except for the OD unit with normal hand tools. You need a shop press for the OD unit and the clutch drums are easier with one. Feeler gauges and a dial indicator are also needed. One thing to consider is that the transmission is really heavy so either rent or buy a transmission jack.
