Got a question for you guys that work on chrysler trannies. Is the 47rh similar to an A-518 except it has a valve body with the lockup passages and valves? Also, if it is, are the lock-up signal valves and oil passages also located in the front support? Is the lockup activated by gov and mod pressure or is it electronic? I have been trained in Allison Automatic transmissions and was just wondering if maybe chrysler was setup the same way. I can get ahold of a 47rh valve body and TC but not a front support. Thanks for any help, Bryan
