After 1k miles on my new truck I've noticed a few things about my auto.
- The shifts are smoother than new, but still hard when over 1/2 throttle
- It works pretty well for a 4-speed in tow/haul (but does not shift nearly as smoothly as an Allison or Torqshift). I do especially like the fact that it will stay in gear down to low rpms and actually use the CTD's torque. Not like the Torqshift that downshifts at the touch of a feather.
- It hangs a bit at 3200 when shifting from 3-4. Not too long, but longer than it should. I haven't timed it yet.
- It has a personality, it seems...
When the truck is parked for more than a couple of hours and restarted, it will take a few seconds to move when the trans is put into gear. Same thing, forward or reverse. If I let it idle in neutral it will go immediately when put in gear.
It also seems like the transmission shifts into OD randomly. Sometimes at 35, sometimes at 45-50, but I have yet to see a trend based on throttle position, engine temp, run time, etc.
I have experienced a similar problem in my pop's '97 gasser. In fact, he still has it. If it's parked for a while, it will not move for several seconds, even with throttle. The truck is now on its second transmission, and it only has 52k miles. It still behaves the same. The original trans had the VB replaced under warranty at 30k miles, but it only improved the shifting while in motion, not the lack of movement at startup.
I was told it's some type of check-valve (on the '97) that's allowing fluid to drain back into the pan. I was also told that the pump doesn't circulate ATF in Park, only in N, so it's not recommended to idle in Park due to a bushing not receiving lubrication.
So I start my truck in Neutral and let it idle, not knowing if it's a bad thing to idle in Park.
I would have thought that 10 years later they would have fixed a seemingly common problem.
Sorry about this "newbie" question, I just don't know squat about automatics. My last truck had a NV5600.
Any advice?
Thanks in advance for your replies.
Any advice?
