My 2003, 48RE trans has 64K miles on it after a rebuild during the Dodge trans-cooler recall several years ago. Total vehicle mileage is 77K, the bulk of which are about 60% lite miles with no towing or heavy loads in the bed.
The trans shifts normally until the engine and trans have come up to full running temperature. Once heated up, the trans will not shift 1-2 until I press the accelerator past a point where I can feel a resistance, or binding, of some kind in the acclerator travel, usually around 20 mph and then the truck will upshift through the rest of the gears normally.
I should note that the spot where it feels like the accelerator pedal binds up only occurs after the engine and drive train have fully heated up. When the truck is cool after starting it for the first trip of the day, or it has set for a few hours, the accelerator pedal will travel smoothly with no binding for the full length of its stroke.
I can get the trans to do a 1-2 upshift sooner during a gentle accleration if I back off the throttle, shift into neutral, quickly stomp on the accelerator to get it past the spot where the binding is felt and not over rev the engine, go back to "D"rive, and then the truck will shift normally until I reduce speed as in coming to a boulevard stop.
When I start slowing down, say 20-30 mph, the trans will do a hard downshift 2-1 as if the gearshift lever was used to force a manual downshift.
Now, whether I come to a complete stop or slow to 10-15 mph and the truck has downshifted to first, I still have to do the accelerate, shift to neutral, stomp, shift to "D"rive, and continue on acrobatics to get up to speed without getting the rpm's to the point where the truck feels like I'm doing a wide open acceleration.
Makes the grandkids giggle but I'm not amused.
I took it to the local Dodge dealer yesterday and they diagnosed it as a shorted Transducer Pressure Sensor. When they test drove the truck after replacing the sensor it continued to do the same thing.
Then they concluded it was something inside the trans and the trans was going to have to come out of the truck ($2,100 for R/R), and when I asked how much further that price would go if they found the failed part, I was told it could go to $4,500 - $4,800 for the total repair if it was necessary to rebuild the trans.
Beings that the sensor was shown as shorted, they left it in the truck and I decided to do some research before committing to $4,800 for a rebuild.
I would appreciate any suggestions on what may be causing this problem, and is the trans with 64K on it really due for a rebuild?
Thanks for your help.
