48re fluid capacity
FASS Filters
Looking upgrade power
Long time listner first time caller!
What is the fluid capacity of an 03 48re transmission. I have 33K on my 03. I don't have any issues with the trans but will be changing the fluid and adjusting the bands at 50K. Will be changing to Amsoil
Posey-smoker
If you wait until 50k and ran above 200* for any amount of time,You should service at 15 to 20K. Don"t worry about the bands,I have had several 47re and a couple 48re and the bands are never out adjustment. If you ran above 220* and do not service at 15k you may have accelerate wear. Trans fluid should be change at temp+miles ,Not miles only. Now if you stay under 190* you probably could service at 25K and be safe. IF ABOVE 230* SERVICE AT 15k MAX.
I almost forgot stock pan 7-8 qts depends on the level and length of drain.
TWest
Thanks I have decided to go ahead and have the service done today with fiter change the bands adjusted. I will wait until next time to replace the fluid with Amsoil ATF.
Posey-Smoker
Originally posted by posey-smoker
TWest
Posey-Smoker
That a good decision, Make sure they only use ATF+4 for warranty reasons
What? got a quote of $200 to change to Amsoil and vendor said 15 quarts? Does Amsoil void the warranty? Thanks, Doc
4 gallons on a complete flush is about right, on stock TC/VB,Pan. NO other manufacture has ATF+4 EXCEPT MOPAR. If dealer is paranoid about warranty work payment and checks fluid warranty work could be deny. I think their are many other products out that will be just fine,warranty reasons only stick with ATF+4. if that is your desire.
