Hi, after reading the 04 Dodge service manual on refilling the 48RE trans after filter change I get two different refill quanities? The one section says 4 quarts
and the other says 1 1/2 ? any idea which one is correct?
STANDARD PROCEDURE - FLUID AND FILTER
REPLACEMENT
For proper service intervals (Refer to LUBRICATION
& MAINTENANCE/MAINTENANCE SCHEDULES
- DESCRIPTION). The service fluid fill after a
filter change is approximately 3. 8 liters (4. 0 quarts).
and in the refill section it says somthing different.
STANDARD PROCEDURE - TRANSMISSION
FILL
To avoid overfilling transmission after a fluid
change or overhaul, perform the following procedure:
(1) Remove dipstick and insert clean funnel in
transmission fill tube.
(2) Add following initial quantity of Mopart ATF
+4 to transmission:
(a) If only fluid and filter were changed, add 3
pints (1-1/2 quarts) of ATF +4 to transmission.
(b) If transmission was completely overhauled,
torque converter was replaced or drained, and
cooler was flushed, add 12 pints (6 quarts) of ATF
+4 to transmission.
(3) Apply parking brakes.
(4) Start and run engine at normal curb idle
speed.
(5) Apply service brakes, shift transmission
through all gear ranges then back to NEUTRAL, set
parking brake, and leave engine running at curb idle
speed.
(6) Remove funnel, insert dipstick and check fluid
level. If level is low, add fluid to bring level to
MIN mark on dipstick. Check to see if the oil level
is equal on both sides of the dipstick. If one side is
noticably higher than the other, the dipstick has
picked up some oil from the dipstick tube. Allow the
oil to drain down the dipstick tube and re-check.
So which is it 4 q or 1 1/2?
any other tips on changing out the filter.
Thanks
REPLACEMENT
FILL
+4 to transmission:
+4 to transmission.
speed.
speed.
Thanks
