48re front pump seal leaking??
can this be removed (PIC) to protect my upper rad hose??
Transfer
My front pump seal is leaking on my 2007 mega cab with only 77000 miles on it. Does the bearing/bushing go bad and cause this or is it usually just a seal. Thanks
Are you sure it is trans fluid and not coolant from the hose back of the turbo?
Some times they will puke a little from the vent on the pump if they are overfull, get real warm, or driving in extreme angles.
Could be the seal, bushing, pump cover, or even the TC.
