48RE might be a good one
Just got a build date
17" Wheels?
I saw a display board that had a lot of the internal changes between the 47RE and the 48RE. Quick summary
Saw a 6 pin carrier instead of a 5
changed the aluminum carrier to cast iron
Pump has more offset in the rotor pocket
and quite a few other changes and they appeared to be directed at diesel applications.
So maybe it won't be a slush box anymore
will it bolt up
what is the chance that it will be able to swap with the 47RE for the gen-2 trucks? If it is better, it might be a good engineered solution to going after parts to build your own.
