48re No Overdrive (3rd gear lock up OK)
Hi all,
First post here... I am pulling my hair out with a problem.
I rebuilt my 48re over the last 2 days. Not a complete disassembly, but I replaced all the friction packs, and the 2nd/kickdown band. Which was the reason I pulled the transmission in the first place. The band was adjusted well past spec, so either wore out or stretched. Turns out it was stretched, plenty of friction material still remaining.
I had a slight 1-2-1-2 shifting problem, so I replaced the governor pressure sensor and the governor pressure solenoid, while I had the valve body off.
Put it all back together... took it for a test drive. Counted, 1,2,3,4 Lockup. All seemed good. It was late, so I parked it for the night.
Got up today, took it for a test drive, 1,2,3,4... no lockup. Got on the interstate, no lockup at the usual 55, nothing at 65, 75... Scratched my head, am I 100% sure it locked up last night? Well, no... since it was late and I wasn't able to drive very long at 60mph... only 5-10 seconds...
Got a pressure testing kit. Hooked it up. On the line pressure seeing 57psi in Drive... rising to about 90 in 3rd. Then jump to 140 psi in 4th(Overdrive). About 100-110 on the the governor pressure port. I think the first run was 1,2,3,4 BUT, on the second acceleration, I only got 1,2,3 Lockup. No overdrive. But, getting lockup now
?? I ran 2 more, confirmed the 1,2,3, LU.
Any ideas on where to start? I already did a switch wire to Pin "7" and at 60mph grounded it. No LU.
Replace TCC and Overdrive solenoids?
Did I put the oil pump gerotor in upside down? I looked at if for a long time, could not tell what side went up/down. Decided it was symmetrical. Now I read that the larger chamfer goes down... Man it looked exactly the same on both sides, but... I could be wrong... Would line pressure be wrong if it was upside down?
I don't have the right computer to check for codes, there aren't any engine codes on the dash. The Tow/Haul, and/or trans temp isn't coming on... Just getting lockup in 3rd, at about 3k rpm, I am just over 60mph.
ANy help would be appreciated.
Hi all,
