After lots of searching for my transmission "problem" on all the diesel forums - the title is from an article in "Search Auto Parts",
which describes it accurately.
Truck = 2005, 48RE - completely stock 4x2, owned since new with 75K on the clock.
Never a transmission problem prior to this.
Maybe this will help others - article quoted - my comments are in parentheses ():
Complaint:
2003 and up Dodge vehicles equipped with the diesel engine and the 48RE transmission may have a complaint of a partial engine stall at a stop followed by a sudden engine rpm increase. This sudden engine rpm increase may be difficult to overcome with the vehicles brakes.
(Yeah - first time it happens it *SURE* gets your attention! Req's *heavy* brake application, or you'll be running into whatever is in front of you!)
Once the vehicle takes off it may be also noted that the upshifts are firmer than normal as the Torque Converter Clutch is On. Note - this complaint does not include a complaint of stalling in both Drive and Reverse, as this is typically caused by a defective torque converter, a restricted cooler and/or a stuck TCC Switch Valve.
(Didn't notice the above. Release brake - with *no* accelerator input- rpms will increase to about 1,000, drop back to idle rpm - then drives and shifts as normal).
Cause:
The cause may be that the Torque Converter Clutch solenoid, is partially restricted, causing the Lock-up valve and Lock-up switch valve to stroke applying the TC Clutch. The 48RE/47RE has 1st gear TCC capability, and when the solenoid is mechanically restricted it will cause the TCC to apply in first gear. The ECM on these Diesel applications can bring engine rpm up when the TCC is applied, to keep the engine from stalling.
(article suggests if the vehicle is hard to stop - put it in neutral at a stop. Yeah - plan ahead for red lights.
No bueno to put it in neutral under the increased rpm load. Better to shut it off in Drive, then restart in neutral)
Correction:
To correct this condition, replace the Lock-up and Overdrive solenoid assembly. (END)
Should add - for me it was intermittent - didn't happen at every stop, but did occur on startup from sitting overnight - in both drive and reverse.
When this first happened - besides some choice expletives, figured it was time to visit Mike at Inglewood Trans.
Of course, when Mike drove it - never happened. Said everything was normal - and NOT a torque converter problem.
And - I had not yet found the above article.
So off it went to a Dodge dealer. They tried replacing the Throttle Positon Sensor - ho help. Remove new part, pd for about an hour labor. They didn't drop the pan - but after driving it - said probably some kind of Torque Converter issue.
(Brilliant)
Then I found the article on the solenoids. Had local transmission shop drop pan (it was clean), then replace the solenoids ("48RE Internal Wire Harness Group" - OD & TCC Lock-up solenoids, as well as a BW Pressure Governor & transducer while they were at it).
No luck.
Sooo - if you made it this far, LOL! - any ideas before I have the trans rebuilt? Cerb?
BTW - Sure seems like some guy's GF, wife, or? could be in a REAL jam when the "first time" RPM increase caught her unaware when she wasn't expecting it - with potentially drastic results!
Kinda like the Toyota throttle sticking "events" and resulting litigation.
Complaint:
Cause:
Correction:
(Brilliant)
No luck.
