The trans. in my truck one day decided to not work. Upon inspection the filter was clogged so I changed the fluid and it worked fine for about ten miles and then it didnt move at all so I removed the transmission and brought the converter to have it cut apart and checked out. I bought an extreme duty rebuild kit from suncoast and a rebuilt front pump from a local trans parts supplier due to dodge being on national back order until sometime in april. The converter shop said the bearing inside the converter let go and beatup the inside so he used my cover on a new converter and reworked the inside of that one. I rebuilt the trans and installed the rebuilt pump, now the trans still has no gears and I checked pressure at the accumulator port in neutral and there is no pressure. I took the transmission apart again and everything appears fine and the pump looks fine. With the trans in gear it would only rev to 2200 rpm but it would not load the motor like if it was engaging two gears at once but it will still rev to redline in neutral. Any suggestions of where to start looking would be greatly appreciated
