My 2004. 5 is a 3500 SRW 4 Door 8' bed 373 rear . The trans. does the 3-4 shift above 2000 rpm different than below 2000 RPM. Below 2000 the shift is crisp & clean the tack drops smoothly from the high RPM to the lower RPM. Above 2000 Rpm the shift seams to take longer. The tack does a two step drop. The engine RPM drops part way to the lower RPM an instant later it drops the rest of the way into the clutch lock up mode. All other shifts are nice, firm and at the right time. The truck has 8k miles and is being run empty. Is this normal?
