Archived 48re slipping
Archived Losing coolant
J.Alexander
Help in Houston, tx. My 2004 5.9 stock, with 48re trans is slipping. Seems to work ok after it shifts to 2,3,4. Does anyone know a good trans shop in Houston?
You are correct! If I place the truck in "1", it starts off normally, I then move to "2", then "3". all ok. But it is apparently not downshifting. Any ideas on what causing this.
Much appreciate the info. Thanks, Jim alexander
Yeah, gov pressure transducer and\or solenoid is the usual cause. Pretty normal symptoms and failure, easy t replace by just dropping the trans pan.
