48RE TC Lockup in 2nd from TSB 18-007-04
OK,
I'm confused. I see threads with people talking about TC lockup in 2nd. My 48RE won't do that. I seem to recall seeing a note in a TSB about adding 2nd gear lockup with a flash, I think it was in the 04. 5 hesitation/white smoke TSB.
Am I correct that the 48RE does not lockup in 2nd but that it can be added through a reflash?
I've talked with my local dealer a couple times, they always tell me they won't perform TSB's unless they see certain codes. I don't have a hesitation problem, guess I could claim poor mileage and white smoke at cold ambient temps - they can't check that until next winter around here.
If I'm correct about the TSB, is 2nd gear lockup available in another TSB?
On edit: Found it again in TSB 18-007-04 - "The new engine controller software also includes a change that allows automatic transmission equipped vehicles to lock the torque converter clutch when a manual 2nd gear downshift is selected. "
Guess I'll go try a manual 2nd gear downshift at lunch today and see what happens. I remember someone saying something about a speed of 27 or 28 MPH.
OK,
