48re Transmission bolt torque values
Transmission Woes
Dealer will buy back my 05 Dodge Ram for what I paid new for it.
Installed a new 48RE in my 2007 Ram 5.9L diesel.
Does anyone know the torque values of:
Transmission housing to engine block (I actually think it is an adapter plate)
4 bolts that go from the transmission mount to the transmission
Torque converter bolts.
Thanks guys
OK. I can tighten them all by hand, but after going to all this trouble, I just figured I would torque them to whatever the recommended torque values are. It should only take me another 10 minutes.
Thanks guys
Bolt, torque convertor 47N-m 35ft/lbs
Trans mount 102 N·m (75 ft. lbs.)
I gave up on the adapter plate bolts. :(
I have to apologize, I missed it that you asked for the converter bolts, my fault.
Yes they are important to set with the right torque - and LocTite.
And gently grease the converter hub that protrudes into the Flexplate.
