Ok, I got my transmission temp gauge installed last night. I installed the probe on the right side on the transmission, near the back of the transmission. So my question is what is a safe temp to operate at with the probe back there I know if you have the sending unit in the cooler line you can run higher temps, but I want to know what temp I need to back out of it from where my sending unit is placed.
I will install the cooler line tap later with the transmission upgrade, this gauge install has already cost me a bunch of $, since I had to install a Fuel pressure that I don't even need
Had to fill the other hole in the pod, oh well
Thanks
Thanks
