About 6k miles ago I got some work done to my transmission:
-I got a Goerend valve body
-I got a new Billet TC (from local transmission shop)
-I also had the lever, apply strap, and anchor band replaced with Goerend parts when the shop did the work.
-The trans shop did some other small work they felt was necessary or a good idea (I think a band, some seals and other stuff. The bill was reasonable so it was nothing major).
-I left the trans shop, drove 200 miles, and hooked a small (single car open, about 4000 lbs) trailer to the truck and drove for 2000 miles.
-Then, I drove another 1500 miles with a 12k lb enclosed car race trailer. This was fairly hard towing, with a lot of stop and start, all over Newfoundland Canada.
-We then hooked our single car trailer back up and headed home.
-When I was towing the big trailer, and later after a particularly long tow (about 12 hours nonstop) I started to notice a vibration in top gear at low RPMS. The problem goes away when you drop a gear, or add RPMs. It is most noticeable around 50 to 60 MPH, light throttle input, with a load.
-The problem is now worse, and shows up with out a load on the truck.
-In total I have put about 6k miles on the truck in the three weeks following the trans work!
As we were on the road, we drove around the problem. I am now home and (finally) caught back up on work so I am just now getting back to truck stuff.
I'm new to Autos, so bear with me
-I don't think this is a TC problem, or it would happen in all gears. Is this correct thinking?
-Could it be a valve body problem?
-Could it be a band problem?
-What else could it be?
I have a call in to Goerend. They called back with in 10 min, but I was busy at work and couldn't answer. I'm sure they will try back soon. I also have an appointment at the trans shop tomorrow to get their input. I just wanted to see what the TDR masses thought so I would be a little better educated when I talk to Goerend and the trans shop I used. Thanks!
